Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
Ok..... I'm glad this post had gotten some attention. What I always do, which I see as the failsafe option. Is to wire the ring cpcs into the socket together, then a single out to the box. It's good to know that these posts are getting read and are being paid attention to.Each to their own but I see that as incredibly bad practice.
Then take some photo's and show us.ive seen worse
it still works, not a fault. just something missing
still no reply from the client, possibly will be left like that for unspecified amount of timeView attachment 14228
if one of the Cpc's is long enough I tend to use one to the box terminal, doubled over not cut and continue it to the socket and join it with the other Cpc so I have two at the socket. If not both to the socket with a link to the box. If that makes any sense.......Each to their own but I see that as incredibly bad practice.
which is of course the correct method which used to be taught at all colleges!Ok..... I'm glad this post had gotten some attention. What I always do, which I see as the failsafe option. Is to wire the ring cpcs into the socket together, then a single out to the box. It's good to know that these posts are getting read and are being paid attention to.
is quite a common thing in Eastern Europe to have sockets in bathrooms. Quite common to have a washing machine there too.
found this today at a friends joiners shop, three phase bandsaw isolator, I was removing the machines to fit new roof to building. Needless to say this will be rewired when it goes back in!View attachment 14305
Yes, it is asbestos, but I was more concerned with the fact that the incoming three phase supply had been connected directly to the fuses, instead of actually going through the switch first!!
He's right, easy to miss that one when just glancing.Yes, it is asbestos, but I was more concerned with the fact that the incoming three phase supply had been connected directly to the fuses, instead of actually going through the switch first!!
Not saying you're wrong, but are you sure? It's hard to tell from the photo (without knowing the model of switch in question) which set of switch contacts the cable entering the bottom is connected to.
btw the fuse carriers have aspestos ribbon lining them, dont breath it
replace the fuses, that way you will be ok, then use a nail bar to remove the isolator from the wall
hi ,my workmate died last year after a long terrible illness, "aspestosis"
he was 58
ive inhaled aspestos dust in the past ,crawling over old pipe lagging in hotel roof voids
i don,t know what coshh means,
this was how it used to be in the late 60,s early70,s, when there was no safety gear
as an apprenice, i use to take big bundles of used/worn out fluorecent tubes and smash them with a hammer -into a dustbin, clouds of white powder everywhere, no mask--we didn,t have a clue
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
