Discuss Threading conduit with WD40 instead of Tallow in the Electrical Tools and Products area at ElectriciansForums.net
Anybody else tried using WD40 when threading conduit? its also good for cleaning the threads as well after you have filed the end with a round file (or used your pliers) and cleans away metal dust better than an old rag....also less messy than Tallow :innocent:
Have tried it when nothing else available seemed to dry up or evaporate very quickly whilst threading.
i like to keep a can of 3in1 in the toolbox. comes in handy if i'm doing a lot of hacksawing. wouldn't use it for threading conduit though, it's a bit thin and would evaporate too quickly - you'd spend a small fortune on dies.
sorry sintra! just noticed that you've already mentioned the evaporation problem.
i use trefolex
Me too, I've been using it for over 30 years and nothing else is quite as good.
Rocol RTD compound or liquid is a close second, but more expensive. However, some prefer the tubes of Rocol RTD compound for the precise delivery, but I've always managed to squash the tube somehow and had a mess to clear up either in the van or worse in the tool bag.
In third place I would put Ambersil Tufcut compound or liquid.
last time i did a lot of conduit work was in a hospital. used lard from the kitchen. was usefull in lubing the cables in as well.
One of our contracts managers years back decided to use wd 40 as a lubricant when drawing cables into conduit and it melted all the insulation.
was at a wholesalers a while ago (edo's) they had not even heard of trefolex and gave us this black tar **** that they called cutting compound
was terrible, was really thick so a pain to get it to stick then as soon as you started threading it got runny and runs off.
usually use the stuff the plumbers/pipe fitters use that comes in a can
http://images.toolstop.co.uk/product/760deff695f8cea39167d3552796f676.jpg
Reply to Threading conduit with WD40 instead of Tallow in the Electrical Tools and Products area at ElectriciansForums.net
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
  • Locked
5K
