Discuss Trouble finding main fuse!!! in the Australia area at ElectriciansForums.net
Danielwareham
Just stated out and having installed a few CU's with success i went to a flat today and couldn't find the main fuse. Hoping to find it with the meter it wasn't there. This was next to the old fuse box under a panel. Any ideas??? No doubt you will but many of the old installs baffle me!
DNO visit i think,probably the fuses or switchgear is contained in one of the other flats,may have been one house years ago and then converted to flats,the supply looks in poor shape.
Look for a meter cupboard in a communal area, in the main hallway under stairs is popular location. It's common practice in blocks of flats to provide a communal three phase supply, with the each flat's and the landlords single phase supplies being derived/shared from the separate phases of the three phase supply in a balanced manner. Often the flats don't have their own individual local supply fuse but share one of the incoming three phase supply fuses with one or more other flats at the communal meter cupboard. The complication and potential disruption this causes when a single flat's distribution board has to be changed is obvious.:mad:
The above two points were very helpful. Found the main intake room after speaking with the caretaker and luckly the flat had its own main fuse. It's also a home TNCS as suggested in the post before. As always learning fast!
That TNCS is perfectly acceptable, its not home made and its how most blocks of flats and estates in London are wired.
Ryefield board at main intake position is the norm, as you have found out.
Reply to Trouble finding main fuse!!! in the Australia area at ElectriciansForums.net
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
I wonder if anyone can suggest a scenario that could have made this happen. I did a full rewire on a two bed purpose-built flat a few weeks ago...
6K
