Discuss Tumble dryer problems advise in the Electrical Appliances Forum area at ElectriciansForums.net
Hi hope someone can advise. My tumble dryer keeps tripping the elecrics 15 min into it's cycle. Just need to test the heater components. To check therostats should my multi meter be on high setting or low.
( Not giving any electrical advice -Water + Electrics ! - Safer = SKILLED)
Is it a vented one to outside / is the vent free flowing .
(Are You not steaming out the kitchen ?)
It' a condenser one not vented stripped it down removed the heater and need to check the thermostats. Using my multi meter but should i put it on high ohms or lowest setting. 2 pins test probe each side i believe it should read close to 0 if working or show open circuit if faulty. Is this correct.
Circuit breaker. Then I've used an extension lead with a reset switch on. The dryer runs a cycle for about 15 min gets hot then trips the extension. Press button to reset start dryer again and runs for a out a min then trips extension been on same circuit for 3 years so that' why I'm trying test thermostats thinking it gets to hot and they trip the elecrics. But just want to test them.
if it was getting too hot ?
then it would trip the thermal cut out in the dryer.
But you say it is trippng the breaker or rcd
this would most likely indicate a faulty element in the dryer
Or even faulty wiring in the dryer
Time to take it to a Pro
Or just buy a new one.
Think maybe you could check on Electricsafetyfirst.org to see if it is a withdrawn one or dangerous in any way. There are a lot of tumble dryers that are defective in some way and have been withdrawn. They seem to be very problematic. We have a Flatley dryer, lasted 25 years and passed it's PAT last month. Can't beat the old stuff.
sounds like element breaking down when getting hot.IR test may help.
@ Vorti. i got a creda one from the council tip for £3 ( donation to the lads' tea fund). had it 9 years before retiring it to a tumble dryer nursing home (local scrapyard ).
You need to do an IR test on the heating element. But an IR tester is a specialist but if kit. A multimeter is not able to poke 1000volts DC into a component and test the results!
You need an appliance repair person.
Only time I have a problem with my drier is when it rains!!;)
Jay
Reply to Tumble dryer problems advise in the Electrical Appliances Forum area at ElectriciansForums.net
Hi everyone, happy new in advance to you all. Wondering if you guys may be able to help with my faulty dryer. My dryer was not spinning anymore...
Hi ... I've made a silly mistake by not taking pics of wiring before starting a tumble dryer belt change. I hope someone can assist. I changed...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hi all, I am here just doing some research. We have a tumble dryer with a moulded plug fitted. The appliance is approx 6 years old and we have...
8K
Hi I'm about to purchase an American style tumble dryer - 4750 Watts. I know this needs hard wired. My question is, can this be hardwired into the...
