Ian B
- Reaction score
- 11
I'd appreciate peoples views on this, including compliance or otherwise with the regs.
I've come across a 1-bed flat where one ring main serves the small kitchen, and boiler & security alarm. The unusual thing is that the ends of the ring are then connected to a single 6mm T&E that runs back to the consumer unit.
6mm is run through ceiling/floor void, holes in joists (no insulation), and down a steel conduit to the consumer unit.
6mm Run length is 20m max and it's protected with a 32A MCB.
Kitchen is being refurbed, and the run back to the consumer unit is really difficult to access, so question 1 is, does the existing arrangement comply with regs?
Question 2. There is also a single 2.5mm radial from the consumer unit (16A MCB) to the Kitchen area (was an old storage heater I believe). Cable is run the same way as above.
Is this likely to be sufficient if they install a simple 600mm wide built-under oven and electric hob?
What about changing the MCB to 20A?
I guess the hob could be powered from the above "ring" if necessary.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
