L
Les Player
I have been told by several users of Visual Building Solar Designer that while using the software to calculate the FIT, they like the feature to select the local irradiance values from a map. However I also just heard from another user, that they have been told to use a single irradiance value throughout the entire UK, and this feature is therefore redundant. The factors from Cornwall to Scotland have a difference of 300 KWh/ sqm, so in my opinion it does matter.
What’s the consensus here, do you use an accurate irradiance value for each location in the UK or use a standard value?
