Discuss Wagos and ferrules in the UK Electrical Forum area at ElectriciansForums.net
Has anybody used a ferrule in a push fit wagos? I need to cut into a ring circuit to make a spur using singles (in conduit) but only have push fit wagos no good for flex as we know. I don't want to make a special trip in the morning and £20 on a box of latching wagos that I probably won't use again . What I want to know is if I use a ferrule will it fit in a orange 4way wago?
Hi,your singles should be stranded,which they accept,i think,from memory.
You could probably push a ferule on a fine wire in,if it didn't exceed the diameter of the Wago's maximum capacity,BUT,you may not find, Wago approve of such ingenuity,
Do you mean Tri rated cable when you refer to flex?
Have you see that crazy PE post about Carbo e-paint. I thought was April Fools for a moment. Didn't want to say anything, think I might have already offended them, being so they are forum sponsors.
Reply to Wagos and ferrules in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi all, I’m after some advice regarding use of Wago boxes for adding a spur off a ring final. Is it okay to use a MF Wagobox with 221 Wago...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
