Discuss Wagos on Final Ring Circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Looking back at original posting to see what its all about, in ~13 JSJW quotes a method for terminating to socket outlets.
I use wago's to terminate for testing at first fix stage but then disconnect and terminate the single core conductors straight into socket terminals for second fix (re-using the wago's eleswhere).
I think (although never tried it) phaffing about with flexible conductor (extra cost and time) which 9 times out 10 would need a ferrule to terminate correctly would be less efficient?
They are £5.99 at Screwfix. When other makers get on board, with single, FCUs. etc, expect them to drop substantially in price, as did screwless downlighters.
They are well overdue. They still do not eliminate Wagos at the back of backboxes for ease of 1st fix testing.
I do not know what max amps the connections on the back of these MK Rapids is. I assume 32A.
Some 4mm radials go over 32A. So best fit a ring in that case.
Nevertheless, a great advance. We are still about 40 years behind Denmark, Germany, etc, where screwless sockets are the norm.
Fitted some 32A triple pole sockets a few years back with push fit connections. Lifted a plastic pin pushed conductor in then pushed pin back down. Wasn't sure about them but they gave no problems.
Not UK 13A 3 pins. What were they?
It is quicker leaving in the Wagos.
30 sockets, which is normal in many homes, can have 90 flex tails. Easy and much quicker when the tails are fixed to the sockets on a bench. Then a sinch in pushing them back into the boxes, with no stress on the terminals.
Also, no terminal has more that one conductor in it. Current only flows through the socket terminals when that socket draws current.
The sockets terminals are not used as junctions, carrying the final ring's load. The superior Wagos with one conductor in each slot, carries the load.
Much superior method.
Safer all around.
Quicker to install.
Eliminates stress on conductors and screwed terminals also.
It can knock a day off an install.
Cables all tested on 1st fix.
30 sockets, which is normal in many homes, can have 90 flex tails. Easy and fixed to the sockets on a bench. Then a sinch in pushing them back into the boxes, with no stress on the terminals.
Safer all around.
Quicker to install.
IEC 60309 32A socket.
New posts
Reply to Wagos on Final Ring Circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I’m after some advice regarding use of Wago boxes for adding a spur off a ring final. Is it okay to use a MF Wagobox with 221 Wago...
Hi, I need to swap out a damaged 30A junction box on an existing ring main circuit and thought I'd replace it with Wago 221 connectors and a Wago...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
