Discuss What is this Prysmian device on telegraph pole in the UK Electrical Forum area at ElectriciansForums.net
Hi I have come home and at the bottom of my drive way have noticed this thing bolted about 7ft up the telegraph pole with a laser/laser radiation warning sticker on it.
Anyone know what this is and what it does or what all the numbers mean?
http://Upload the image directly to the thread.com/JhozEQL
http://Upload the image directly to the thread.com/sDIfSqG
Upload the image directly to the thread - https://Upload the image directly to the thread.com/JhozEQL
Let's see if this link works for the picture :)
But just in case it doesn't, it's a Prysmian optical fibre jointing system. I suspect the numbers are circuit/service identifiers and the laser radiation symbol is on there so as to make sure people don't open it without suitable eye protection.
Awseome thankyou, nothing to worry about then?
BT were pulling the copper cable out round our way a few years ago, apparently BT was getting £3000 for a skip full.
BT copper pairs are horrible to work with, they're packed with grease. stuff gets everywhere...
But you have to account for all types of idiots !
And Sharks
For sure it's a fibre optic repeater / booster,
The radiation warning is for the laser diode.
But unless your looking down the fibre when it's on,
Then their is no problems.
Hate to disagree, but I don't believe it's a repeater... reasoning... only two 'cables' entering (if it was a repeater I would expect to see a third - the power supply), plus there is no warning about the presence of potentially hazardous voltages you might expect if there was a power supply present in there. Plus I don't believe Prysmian make repeaters.
The laser radiation warning is required as if you bend a fibre beyond it's minimum bend radius there is a good chance the reflection fibres require to work will break down (the angle of incidence will be too great) allowing laser radiation to be emitted from the sides of the fibre, whilst not as potent as looking down the end of a fibre, it is still strong enough to cause permanent retinal damage.
Reply to What is this Prysmian device on telegraph pole in the UK Electrical Forum area at ElectriciansForums.net
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
