Discuss what size wire in the UK Electrical Forum area at ElectriciansForums.net
I need to install a 30amp service for a camper , would be a 600' pull from my source, is it possible and what size underground wire would i need, copper and aluminum. Thanks in advance for any info.
At that distance you could probably get by with # 6/3 with ground romex approved for outdoor use. I always use copper wire. I don’t know what load the camper is going to pull, having said that if you don’t have cookers, water heater etc. you could probably get by with # 8/3 with ground romex approved for underground use of course
Thanks for your reply, i already ordered some 2/0-2/0-2/0 aluminum, thats what the online calculator recommended. thanks again
Reply to what size wire in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
