Discuss What type of receptacle for 208/1 - 25.9 amps in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Sorry, lengthy post. Really only need to read the next sentence to be able to answer my question. The rest is what I have considered and how I developed the question.
Can a NEMA 6-30 outlet rated for 250 volts be used for single phase 208 Volts?
I am a relatively new estimater doing a takeoff. Most of the time I am quoting Fire Alarm, so I have a lot to learn about power. The drawings show that I will need a receptical for a 208/1, 25.9 amp piece of equipment. They provide no further detail, other than the height off the floor. I am assuming the /1 means single phase. My plan is to quote 10/2 MC cable, as I believe I only need 2 hots and a ground for 208 single phase. The receptacles are not specifed. Would any NEMA 6-30 outlet do the trick, even it it is rated for 250 Volts? I can not seem to find any receptacles rated for exactly 208 volts and I am guessing that 250 volts is the nominal design upper limit of all receptacles in that class?
The closest I came to answering my own question is that a Nema 6 outlet provides for 2 hots and a ground. It is reated for 240Volt split phase or 208 WYE. While I think I am on the right track, I am not convinced because it does not say 208 volts single phase. Seems misleading because wouldn't a 208 WYE on an outlet that provides for only 2 hots and a ground be single phase? Guesse the WYE is throwing me off because I associate that with 3 phase. Maybe the designation in this case just means that the 2 hot leads are 2 out of 3 leads from a WYE. Correct me if I am wrong, but 208 3 phase would not work with this outlet as it only provides for 2 hot leads. I think I am answering my own question.
Thank you
Reply to What type of receptacle for 208/1 - 25.9 amps in the UK Electrical Forum area at ElectriciansForums.net
Hey so I need help understanding this question and understanding it in the NEC.The service to a multistory building is 277/480-volt, 3-phase...
Hi there im in training, but my question is using using a 3 phase 480v delta to 208/120 delta transformer 30kva and wiring it in reverse for 208...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
