Discuss Would really appreciate some advice on faulty wall socket in loft in the DIY Electrical Advice area at ElectriciansForums.net
TommyTee
I have a double wall socket in the loft that isn't working, its directly above the control panel and switch for the underfloor heating in the bathroom on the floor below. It doesnt work whether this is switched on or off.
When inspected the socket I noticed it looked like the black wire on the left may be loose (I've attached some pictures), could that be what is causing it not to work?
Would really appreciate some advice from someone more knowledgable than me?
Thanks in advance:)
[automerge]1589116113[/automerge]
The pictures didnt upload so here the links to them
They look like a pair of 6.0 T&E cables which are pretty large to fit into a 13A socket outlet. It is possible one isn't making contact but if you can't pull it out it is probably okay, the bare earth wires also require green/yellow sleeving. Do you know where else it goes because that isn't end of circuit.
Reply to Would really appreciate some advice on faulty wall socket in loft in the DIY Electrical Advice area at ElectriciansForums.net
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
This is a rather basic question, so please accept my apologies. I couldn't find the right search term, and I thought my situation was a bit unique...
Hello everyone and thanks in advance! So, I installed this LED fixture in my bathroom to replace an old fluorescent fixture that had a bad...
