Discuss Dado trunking opinions? in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
I've got a shed load of dado trunking to purchase and install on a office refurb that im starting after christmas. Just wondering what people's opinions are on best make for ease of installation, cost etc. I normally use MK but its pricey but I like the way it all goes together, I've also used some proper crap in the past that's why I would like some opinions.
I have installed without exaggeration literally hundreds of lengths of the Marshall trunking and it is good kit, you asked for advice, I did my bit for you, I hope you find something in anycase.
See my PM!
Like MDJ i have used Marshall Tuffnell Dado and angle profiled trunking in labs and workshop almost exclusively, apart from some medical rooms. Providing you use their snap-in accessory back boxes, you can't go far wrong....
MDJ and Eng54 don't no whats happening to my ipad it's playing up and can't like your posts but much appreciated, I'll have a butchers at the Marshall tufflex range and see what prices are etc
No the worst ever is the galvanised stuff.
MK is good, they do the newer VP range which is a bit pricey, but if you go to Neweys, their own brand 3 compartment trunking is the old MK VTS range, so quality is still good with low prices.
I found with the MT sterling trunking, once on the top and bottom lids were on they were difficult to remove.
Also the protective film was applied so that it got stuck in between compartments and the walls so when ripping it off at the end of the job you had to remove the lids again to get all the annoying bits of blue film off.
I'd suggest peeling the film away from the edges when installing the lids in the future.
I am surprised no one has mentioned Rehau? I have only used it a couple of times due to a complete lack of commercial work but its always seemed brilliant to me!
well it needs to be secure to stop kids pulling off lids, which in some schools would be a given, I have seen them wreck things lol, regarding the blue plastic protecting the lids, umm yes you remove the edges previous to fitting, experience will ensure you don't do it twice, certainely not a fault with the trunking is it?
Surprised at the flack aimed at centaur maxi trunking. We use it exclusively in schools where practicality and cost are more important than aesthetics.Never had any issues with it as long as it's installed properly. Centaur mini trunking is also streets ahead of marshall tuflex. MT trunking is impossible to make a neat job of mitering or double setting. I can form just about any set in centaur trunking so that it looks 'manufactured'. I recall rewiring a primary school with minitrunking drops years back and it was necessary to double set over a lip on the wall.....architect couldnt believe the sets were not preformed.Would have looked crap with MT trunking.
Eh? all mini trunking is the same size, mt2 or yt2, or mt1 or yt1 or whatever, there are 3 or 4 sizes all manufacturers make which are the same size as other manufacturers, why does the MT differ from CEF ****e?
On Marshall tuflex the lid lip is about 1/3 the way down the trunking,which makes it impossible to form neat mitres.I've seen some of the crap installs by contractors with other makes where a situation isnt met by preformed angles,usually involving a lot of filler.On CEF minitrunk the lid is flat,and clips directly onto the top of the trunking,and it can be formed easily into really neat mitres and double sets. I have used various makes of minitrunking and centaur is by far the best.
As far as their Dado trunking goes we use 100x50 maxitrunking for practicality and economy.Not on a prestige job I would agree,but for an economical dado trunking in an office or classroom it is perfectly good.
If I get time tomorrow I'll knock up a double set with centaur mt2....and marshall tuflex mt2 and post up pics.
Clearly if you think centaur and MT minitrunking are identcal then you havent used centaur. I find it hard to take someone seriously who condemns something as sh-eye-t without ever having used it.
I have used Centaur trunking and would say you get what you pay for only used it once and never again was not impressed by the quality and a few years after installation it was quite discoloured
From a buyers point of view ...you need to consider price, quality, ease of installation, availability.....Get your local Wholesalers involved if you've got quantity to order, they'll sit up and take notice ......get 2 or 3 involved.......maybe an independant and a couple of nationals....and let them know you've gone out for prices...see if you can get a project price for branded stuff such as Ega & M/Tufflex ....make sure you price the accessories as well as the Trunking (you may find the price of Trunking to be reasonable....only to find the price for corners / inserts etc.... to be extortionate)...maybe offer to do a deal whereby your supplier gets it in and then invoice you, as and when you call it off (that way they are guaranteed the sale for the whole project).......don't discount Own Brand stuff such as Newlec or Sector ......they are both manufactured by MK / EGA .....Just older versions of Prestige.........another tip if you use Ega Premier Trunking...NCT 1050 etc .... Newlec and Sector own brand inserts are identicle to VTS6025's & VTS7025's and you should get them for half the price.
In this cold weather , you have to be careful with the PVC trunking of all sorts , Dado or skirting trunking corner pieces are most prone to damage on the small rear fixings , pays to keep them somewhere warm if you can before you use them ..
installed a load of starline chamfered trunking pretty reasonable price from tlc easy to install and looks pretty decent . would always use pre fabricated bends and a chop-saw when doing dado.
I have used it hundreds of times, the lid falls off if you hold the length up vertically, yet is almost impossible to remove when flat on the wall, cheap rubbish.
Cant believe that statement. If you dont like it fair enough,but the centaur I use has completely secure lid wherever it's put. I'd totally agree that most CEF gear is junk.....but NOT their minitrunking.
Well thats my opinion, if you don't like it there is nothing I can do to cheer you up, I won't retract my comment regarding it, IMO it is cheap rubbish, just like their dado trunking.
fair comment, if you like it then thats good, I respect your opinion.
Yup marshall is the same, I prefer plastic pipe rather than minitrunking.
what im saying is, if it has been put on properly it doesnt fall off, we use it all the time on door access and not see any lid that has fallen off etc
that was marshal minitrunking
this is centaur
look at the lip it is different and that cef one is ****
cut a meter off a length of CEF trunking and then hold it vertically, the lid will more than likely slide off, put it on a wall and then try to pull the lid off, it is tight, very tight, I just don't like the stuff and I am afraid I won't be changing my mind about it either :biggrin:
yes thats centaur you dojt like.
you cant put marshal lind on centaur or vice versa, there different.
...surely this thread has got to the "if a tree falls in a forest with nobody there,does it make a sound" ...stage :conehead:
To whom it may concern i used the decoduct interplast dado trunking yesterday it was quite good. it comes from united arab emirates
Mate I respect your opinion but have to say I am honestly baffled by your comments and can only assume we are not referring to the same trunking. The centaur I use has a lid which fits perfectly,neither tight nor loose,and I can assure you it will NOT slide if you hold it upright. Because of the lid profile it is the only minitrunking it is possible to form neat,self supporting sets and angles. The lid is tight enough to be secure in use,but easily removed if needed.The older stuff admittedly used to yellow and go brittle,but this was sorted a long time ago.
Here is centaur MT2 which I use,
side profile
top profile
Reply to Dado trunking opinions? in the UK Electrical Forum area at ElectriciansForums.net
Came into work today with a fairly urgent requirement to install an instant hot water handwash unit in a small commercial kitchenette/servery -...
I'm a bit out of touch re 18th edition. Is it really necessary to fit loads of additional metal saddles inside trunking when it's only 400mm...
Hi guys, I've got a job where I'm installing dado trunking on the floor of an office for sockets and data. Some info on job - In total I will be...
5K
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
