Discuss Size of shower cable in the UK Electrical Forum area at ElectriciansForums.net
Well if Baldsparkies wasn't bald, he will be now! Crikey, a vague question got a vague answer, like most questions and answers on the forums! All this bickering over such trivia lol. Come on chaps :)
I started off bald so I have nothing to lose.
But nine pages in, what the hell do you think the DIY electrics, plumber feels like who asked the damn question in the first place. lol.
Its even more rare to see 230v shanks, and often that's the baseline that's used for obvious reasons.
And yet when I dared to suggest 6mm as a possible cable size for 8.5kw I was summary abused ??
Despite that, it will be used. And if Mr DIY is going to use it it's wrong.
But on an electricians forum, and with all other factors taken into account, can can and does prove satisfactory in the real world.
So there you have it, some people are getting trashed for saying 6mm, some people quite happy to use 6mm.
Hope others are paying attention here, cus amongst qualified electricians there are indeed differences of opinion, and you know what dependant on the situation both are entirely correct.
And that's the whole point, and no abuse needed.
I swear to God you're gonna start seeing some abuse in a minute if you don't settle down!!
NOBODY HERE HAS ABUSED YOU YOU PITY SEEKING LOP!
It wasn't your suggestion about using 6mm cable on an 8.5kW shower that was wrong, this was just inaccurate. What was wrong however was for you to 'suggest' in the first place! What is so bleeding hard for you to understand?! You've been told God knows how many times already!
No matter how much detail you go in to about cable calcs, design, derating blah blah blah, when you are describing how to do something to a plumber on an ELECTRICIAN'S forum, all they will see is "put an 8.5kW shower on a 6mm cable".
Please tell me that this has sunk in finally?!
Genuine mistake and he gets abused ie accused of being a dxck lol
I have to laugh because you couldn't make it up :6:
Shocking that it is allowed to happen. I just got banned for starting a harmless thread in which I even said I was only joking. It will be interesting to see what is dished out after reading some of these replies.
I have to laugh because I spotted the error straight away and I'm sure a few others did.
Ideal opportunity to dig you out though, if your that way inclined, nice little cover.
not wrong, IMO. yes, i know that the lower the voltage means a lower kWage. what i meant was if you calculate from the quoted kW @ 230v you will get a higher value for A than if you'd used 240V. as in I=P/V
7kW @230=7.55Ω=30.43A
220V=29.11A 6.4kW
240V=31.75A 7.62kW
250V=33.08A 8.2
The resistance is regarded as constant.
so, power output varies with the voltage.
in this case what the op was asking is ohm's law, the basic's of the basics.
V=R/I
I=R/V
R=IxV
bassically to start with a 10kw shower would be 10,000 / 230 = 43Amps
so now you have your design current for your cable calc.
the cable you need for a 10kw shower depends on installation methods (clipped direct)
if it has loads of insulation along the route and other factors you might need a 16+mm cable (this is why we calculate cables in the first place)
and to answer your question, the members here get that bored and wound up from giving people the same advice everyday on how to wire a shed they get ratty
i think you have a typo mate.
you put 5.8kw i think you mean 8.5
Please can you fix your typo in the first quoted post before it gets taken as gospel by trainees etc.
So you are back and immediately you are being a dxck.
Please don't hand out detailed advice on the public forum
Enough!! You're the one trolling for trouble here so stop it and leave moderating to the Moderators.
It is only your assumption and opinion that the OP will only gleam a section of my reply to him, and use it out of context.
Like it or not that is fact.
For that reason your argument is flawed.
The problem is, you are finding it difficult to comprehend that I am failing to bow to, as said, your opinion.
When reading instructions, advice, reports or anything else.
You read the entirety of what’s being said.
If you fail to do that, and take sentences out of context, you do so at your own peril, and that’s certainly not the fault of the writer.
Internet searches will provide many opinions and statements on all kinds of subjects, so the OP can freely read whatever he chooses.
My comments were not inaccurate, and I certainly did not say the OP could use a 6mm cable for an 8.5kw shower end of.
Although circumstances permitting, a 6mm cable will suffice.
The OP is a plumber, presumably by trade and plumbers are not idiots.
In fact I have come across many plumbers who have a very respectable knowledge of electric’s within there own field of expertise.
So to conclude,
I disagree with your analogy; I respect a few others on the forum may well back you with your analogy.
I think you are wrong to be so persistent and just accept that people can, and will, have opinions that differ from yours.
Learn to accept that, without blowing a head gasket.
Now to use your own words,
End of conversation,
Its time to move on lad.
i just swapped them all around after marvo asked.
they are wrong yes
Just see the V I and R in a triangle in your head (draw it first if you like)
V at the top
I bottom left
R bottom right
That way its easy to see the V divides by I and R.
And the only multiplication is between I and R
So
V/I = R
V/R = I
I X R = V
Three days, thirteen pages, 149 posts and we're still arguing about what size wire to use for an electric shower and not a Electrical Trainee in sight!!
A whole forum of properly trained skilled tradesmen can't decide whether to use 6mm or 10mm cable to wire a .........
............ shower??!! :biggrinjester:
And we haven't got to the CU that it's going to be terminated in yet .... Steel or plastic???
Geordie, seriously mate, that's got me in stitches, and you are so, so, right.
I don't know what size boot you wear but I for one, have just taken a kicking from it with respect to you.
I'm usually a level headed bloke in the real world, but this bloody forum is turning me into something that to be honest, I don't like.
I've been around long enough not to contradict myself, but that exactly what Iv'e done.
Thanks for kicking all of us who have been knobs into touch.
Least of all me mate.
Reply to Size of shower cable in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
hi ive got an unused isolator in my airing cupboard that use to run a shower. no longer have has have combi boiler feeding a new shower. the...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
