G
Guest125
No worries boss, tell NR to send consultation fee to TJ![]()
£1.50 in the post....
Sorry. Again this is fine but if there was any other access (cleaners/security) then no lights.
We could bat ideas back and forth but without a on-site meeting and discussions about who may need access whether they could be provided with a key switch option etc ....I just see using PIR as problematic unless we know all the circumstances...What if there is a fire will this become and exit route - this changes all the requirements etc
You need to gather all the info...ask the questions you put as scenario's here and until then there is no real solution without a operation usage detail....so until then we are all guessing and may not have vital info.
Id go pir myself. If the timing duration is left long enough eg for length of peak hour you are not putting any extra undue switching on the lights and you are not restricted to set times
Surely they will need some sort of lighting on if they have all them cameras?
Good point. I never thought of that.
But the cameras will only need to record if somebody is there, and if they are there they will trigger the pir.
You won't running pvc/pvc cables above that ceiling. This needs a bit of thought and I'm surprised your being given the responsibility to come up with a solution and it ain't a dig at you mate.
Some one with a lot more qualified and experienced ie an Engineer should be doing this imo
With the overlaps of security,emergency,fire regs and probably half a dozen other factors,i would be disappointed if a set of anonymous dudes on a forum,come up with the spec....:conehead:
