dal_87
hi would like some info regarding fitting fcu near kitchen sink. now i know as good practice it should be min 300mm away from edge of sink horizontally , but in a job iam doin tomorrow i require to go vertical. does this still stand ? iam installing a hot water urn in a staff kitchen in a college, the kitchen is small and the supply will have to be above the sink area ...can i (A) just install fcu above with min 300mm or (B) look to install fcu near ceiling and drop down in a flex outlet plate .. all will be surface mounted .. looking for some guidance thanks in advance
