Sorry I don’t follow you?
What's the general scenario when a diyer removes a light fitting, changes it and then can't understand what's wrong?
IMO if the OP, who as it seems, has received conflicting advice, the training center's usually have some affiliation to a CPS member, example NICEIC approved, that sort of thing.
If he get failed for taking the advice from his Tutor, and it proves out to be the wrong advice, as in this case, I feel his recourse will be to contact the CPS and air his complaint to them, whether he will get anywhere is debatable, you have to agree to that surely, or maybe you don't.
I see where your coming from now regarding the affiliation, I think it is mostly with the NICEIC and C& G some aren't though. In my day and maybe yours you only had the FoE run/funded (in part) by the Departement of Education you didn't get all these commercial education providers. I can see the point that the training centre would want to see the student installing as taught but sleaving brown complies with the regs.
Deleted
the only reason we use blue with a brown sleeve is when using T/E where there's no option. in ROI, they use twin brown for switch cables.
In all of Ireland twin brown is used, although in the south it is prohibited to oversleeve.
Never seen twin brown here in the South of England. However used to see twin Red quite a bit.
Serves a purpose, but it's a pain in the bum when you accidentally wire a complete lighting circuit in the stuff.
Reactions: Flanders
It would matter if you had a 2 or 3 gang switch and needed to loop the L to the other switches.
Just connect one of the browns to the cpc and bell it out. It really doesn't present a problem. Worth remembering that bs7671 expresses a preference for conductors to be identifiable throughout their length and not just at the terminations.
If someone did it with a single I would expect them to rewire it properly.
@Risteard doesn't the Republic of Ireland have it now that in T&E the CPC is both sleeved throughout and of the same size as the Live Conductors?
An incorrectly pulled blue single sleeved and used as a line is very shoddy in my book and I would not permit it on new work at all. Forgive my unfamiliarity with T+E (I only work on projects that are in steel con, SWA and pyro) isn't twin brown usually made with one core insulated with solid brown, and the other brown-skinned white insulation, so you can tell the difference during installation? I've certainly seen red done that way.
Continental Europe does generally use an equal gauge insulated CPC but it's normally in a round cable rather than flat. Aus & NZ also have their CPC like that but the cable is flat like ours. USA T+E has bare CPC.
Reactions: Rpa07 and Risteard
I have some twin brown and there is nothing to distinguish the core by insulation variant.
I have half a roll of Portuguese flat cable in my garage.
Not seen twin brown, but the twin red I’ve seen had nothing to distinguish the cores.
Sometimes the browns are slightly different shades...good luck with that in good light let alone poor light. Have seen them as Lucien says also.
Last time I used Twin Brown it was an incorrect delivery from wholesalers and I wired a lighting circuit with it:rage::rage::rage:
That's correct. The implementation date was the 5th September gone. It's roughly 30% dearer than BS T&E for IS T&E.
  • Informative
Reactions: Des 56
Would save on green and yellow sleeving, And no more multi cpcs crammed into 1 length of sleeving
Reactions: 123
Who's right? Hopefully me!
Drew34,
Pete999,
