Unless I'm mistaken, in Aus there is a special cable for switch drops with red and white cores. They still use red/black/G+Y so red carries through as the PL and white is the SL. That way you can tell at any fitting which is the switch drop and which of its cores is PL & SL. No sleeving or belling through required. I would have thought brown/black better than brown/brown for our own version.
OTOH in the USA, historically they used normal Black/White/CPC T+E (i.e. Romex / NM)for switch drops but PL and SL were reversed relative to UK practice. White (normally neutral) was sleeved black to make the PL, black (normally hot / line) was the SL. This made the colours at the lamp terminals correct, and the PL of the switch drop immediately identifiable at the loop-through as it is a white sleeved black. Sounds a bit funny when you're used to doing it our way but it makes sense. Since 2011 (?) switch drops are normally 3-core as a neutral is required to be available at switches. As their 3C+E contains black, white and red (second hot / SL) they don't need to sleeve as the colours (sorry, colors) are already right for PL, SL & N.
