Discuss TT or not TT. Need clarification in the UK Electrical Forum area at ElectriciansForums.net
Stix
As per title; having a pre fab shed in back garden installed on a concrete base that will have a dp membame. No reinforcing mesh. 15 metres from house. Looking at spurring off socket on back wall to an rcd spur. Runn8ng down outer wall in conduit to a weatherproof box. Then using 4mm swa to shed. Shed will have no gas/water but will have a metal door and galv pearling beams for roof. Only used for mowers;strimmer and a chest freezer. One led light to be fitted also. Am qualified c a g 236 pts 1 an 2 but out the game for 10 yrs. Is TT needed? Was looking at fitting a garden shed tyoe cu with 6a and 16a mcbs. Sockets woukd be rcd type for protection
file:///C:/Users/Pete/Desktop/Resources/Garage-Shed%20Supplies(1).pdf
House has PME earthing, am not sure as to wether roof beams made of Galv would be classed as extraneous. However the door is made of steel, so thinking is it worth TT ing
Have you tested the Beams and door to see if they are Extraneous?
Being as the is no extraneous parts (including the shed) no need to TT. Why not switch fuse spur in house to double socket in shed to switch fuse spur (with 3amp fuse) for the light?
Sounds good, and good to see your thinking it through & planning rather than just lashing it in as you go.
if you're coming off an existing RFC that's RCD protected, it's pointless fitting another RCD in shed. can you come from a non-RCD way in the CU instead?
Would the steel door not count as been extraneous ?
not really as it's a lot further and a hell of a lot of upheaval to my home. That's the reason why I'm going down the spur route. May go with big sparks 17 id a. Was I maybe overthinking things? Am in no way going to o load circuit as only constant supply would be small freezer, and that's only if we decide to get one!
Not really a very good idea to spur from a 32A RFC wired in 2,5mm2 cable, connecting it to a larger csa cable running it 15 Meters and slapping a Garage CU on the end of it, that wouldn't be classed as a Single spur, as you will be adding a CU and a lighting and socket circuit to the mix, far better to run a dedicated supply from the CU in the house, I know its been done before, but it's not compliant, therefore may, render your house insurance invalid.
Not a very good idea to spur off a 32A RFC wired in 2,5mm2 cable, connecting it to a larger csa cable running it 15 Meters and slapping a Garage CU on the end of it, that wouldn't be classed as a Single spur, as you will be adding a CU and a lighting and socket circuit to the mix, far better to run a dedicated supply from the CU in the house, I know its been done before, but it's not compliant, therefore may, render your house insurance invalid.
But I'm sure he intends connecting it all through a 13a FCU at the house end Pete which makes it fully compliant. As suggested though he could then go straight to the socket/s in the shed and use a SFCU with 3a fuse for the light so no need for a CU.
That's yoursuggestion Dave, which is a valid one, personally I don't think the OP will take your advice, one thing I don't agree with is the change of cable size, seems illogical to me, as your suggestion states to use a 13Amp spur at the house end, so why use the larger cable it's unnecessary, and goes to prove that although the OP claims to be qualified, in reality he needs to brush up on his decision making. There I've, said what I think, I'll say no more, as I think I will just be going around in circles.
Ah but nothing wrong with a bigger cable to minimise volt drop/reduce Zs and 'futureproof' Pete. And if I had a suitable length of 4 or even 6mm SWA 'in stock' when a similar job came up it would surely be put to good use. :)
Could be that, but I'm not sure, I'm not an optimist Mate, trust your reasoning though.
Is the existing ring final circuit rcd/rcbo protected if so what is the point of an RCD in the shed or an rcd spur?As you say you cant take the cable back to the consumer unit feeding the shed from a 13A switched fused spur and fusing down to 3A for the light seems ok but preference would be to be on own circuit.Pete can't see the problem with using a larger SWA.
Judging by what you have said I would just extend the PME earthing arrangement.
No extraneous metallic parts so no need to TT as I see it.
The "in stock" and futureproofing" is very accurate in my choice of cable. As was the volt drop consideration.
I suppose you are right Dave, nothing electrically wrong, butcould be just me being ----, now no jokes please.
It's like our shed Pete 20A C RCBO 2.5 T & E clipped to isolator switch through the wall to adaptable box 6.0mm SWA as it was left over (FREE) left over dado above the workbench each side (Free).
Sorry for delay in response guys! Was thinking of using an RCD FCU in house to feed concrete garage; so as to reduce risk of rcd knocking out circuits on CU RCD protected. Only feeding chest freezer(if we buy one); spurring off fir a led light and garden eqpt. As in lawnmower strimmer etc. Can anyone see any pitfalls in this set up?? Thanks for any advice !
Reply to TT or not TT. Need clarification in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
Hi, I am a basic DIY'er, with basic electrical skills, NB, I can change a plug/fuse, change a ceiling light fitting, change a socket face plate...
Hi We just moved into this house and in the utility room there is a normal wall socket with a plug going up ontop of a wall unit and into a very...
Morning everyone It seem I have another outside job. this time the run is 44 metres with about 2 metres going into a chase in a concrete path so...
Hi all, Planning on wiring my neighbour's summer house which will be 15 metres away from the end of the house (20-25 metres total distance from...
7K
