TJC1
Feb 23, 2014
167
Morning all
Need some advice on pricing a 6 bedroom house with a swimming pool.
Im use to pricing your average 3 bedroom new build but this is another step for me.
The house is 37m x 24m
Ground floor: Play room, family room, dining room, gallery/entrance, kitchen, pantry, study, sitting room, gym, utility room, plant room, craft room, gardeners wc, swimming pool
1st floor: 6 bedrooms, all en suits, 3 have large dressing rooms, ac room, laundry room, gallery/landing
Most downlights everywhere, all data and tv in rooms, 63a supply to swimming pool for now, no info on heating yet
Could you not get the price you charge for doing the same to a 3 bedroom, divide it by the number of rooms, then times it by the number of rooms in the big house.
See what figure you get then, as a ball-park figure
Not a bad shout
100A supply I assume?
63A supply for the swimming pool? How much load will be connected and for what duration?
Houses this size can spiral quickly ...
I have worked on 6-7 bed houses that start off at around £100k then quickly spiral up and up and end up at £200k..
I have worked on houses with a £350k electrical budget.
Are you supplying everything??
What accessories are being used?? Very Unlikely White plastic will be spec, so you could end up with Wandsworth accessories at £30 a double socket
Is there a Lightning design ??
Could you not get the price you charge for doing the same to a 3 bedroom, divide it by the number of rooms, then times it by the number of rooms in the big house. See what figure you get then, as a ball-park figure
I think the above approach will likely underestimate somewhat.
Last large house I worked on, similar size/rooms, there was a lot more installed that you'd expect in a typical 3 or 4 bed.
Some examples:
- Marker lights in ensuites activated on entry, so you don't need to put on main lights in the middle of the night.
- Marker lights on staircases.
- Wardrobe lights.
- Data & speaker cables from everywhere back to a central cupboard.
- Some rooms had 7 speaker points, others maybe only 4 (we used 2km of nice speaker cable).
- Separate satellite & freeview coax distribution
- Kitchen big hob, 2 regular ovens, steam oven, warming drawers, built-in microwave, etc.
- Some 3 or even 4 way light switching (e.g. landing lights).
- Beside lights plus 3-way switching for main bedroom lights.
And the accessories will all be some decorative finish, perhaps grid switch modules.
If your talking in those terms, I'm sure there would be a full spec involved.
Is there, by any chance? It doesn't seem so.
Reactions: TJ Anderson
Ask for a full spec of what they want. If they can't then say you are happy to design it for them, consulting as you go along.........on day work :)
Reactions: FatAlan
Leesparkykent is familiar with this type of top end new build and pricing. There is usually a lot to get involved with.
Back on topic... if you only have a single phase 100A supply, that 63a swimming pool heater is using nearly two thirds of what you have available, with no diversity available on that circuit. In fact if the pool heater is on and the kitchen is in action, you could easily be drawing over 100A before allowing for anything else. A gas or oil fired plant room will come with cheaper running costs, if you have any influence over this. If however the supply is 100/3, as is often the case is many older large properties, then you'll have plenty of capacity to design with.
I know where you're coming from, but it's not that realistic that a domestic kitchen will be pulling 37A (or at least for any length of time).
Reactions: TJC1
Thanks for all the reply's! Its in the early stages at the moment so only have some info.
They have asked for a standardish spec at the moment as to there usual house builds . Currenlty looking around 4/5 sockets in each room, down lights to suit the size room with a dimmer, 1 dual coax and one cat6 cable. But they think the spec may change as it goes on, they want to give a client a "rough idea" on price. They have asked for brushed stainless throughout
Not sure on the supply, but im guessing it could potentially be 3phase as the area has houses all around the same size with swimming pool, large plant room, heating etc. I have a friend who did a similar job and allowed a single phase 63a supply for a swimming pool on the price as i have no spec on the swimming pool
SPDs...
In this case I would price as you would normally price a job , per point white plastic and your standard led downlight etc etc
On jobs this size I then work out a list of wiring accessories I need and give it to 2 or 3 wholesalers to quote on in your stainless.
Add this to your original estimate and you have a very rough ball park figure for the customer
Ive just priced a 5 bed house 2 bathrooms, no pool.
Basic install onependant per room, basic number of sockets, gas cooker, mixer shower, nice and easy. £6500.
I spent 2 hours with client at address going over specs and 4 hours writing up quote.
He got a bit of a shock at price and was quoted less, but went with me because the other spark spent 15 minutes looking around and sent an undetailed quote with a price.
Pricing larger new build
TJC1,
Risteard,
