Discuss GU10 LED on 12V DC in the UK Electrical Forum area at ElectriciansForums.net
MikeDIY
I have garden LED light running fine through a transformer..
LED Driver Adapter AC 220 -240V To DC 12V Transformer
But am now trying to add a new downlight with a GU10 LED bulb, however the bulbs are not lighting, looking at the bulb box it asks for 220-240 AC
I am struggling to find a GU10 bulb that seems like it will work on 12v DC, but none of the bulbs I'm finding are mentioning Volts, just Wattage. It does not make sense to me, which bulb do I need?...
https://www.NoLinkingToThis/c/elect...on=warm_white&dimmable=dimmable&sort_by=price
GU10 lamps are 230v.
GX5.3 lamps are 12v.
Ok thanks, is there not something I can do to make this work?
I could try moving the transformer to run only the 12v LED lights and let full 230 to go to this light, only reason I didn't do that in the first place is that someone told me its not a good idea to run full power down the garden
You'll need 230v to make GU10's work, there is no reason why garden lighting cant be mains voltage but it must be done properly, and must be 30ma RCD protected.
Reply to GU10 LED on 12V DC in the UK Electrical Forum area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I have an old IKEA Norrsken 12v suspended ceiling tension wire system, which runs x7 20w MR16 bulbs, from a Min 4x20w/Max 10x20w transformer. Can...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
