Discuss Testing lamp is rewired safely in the DIY Electrical Advice area at ElectriciansForums.net
TheNice
Full disclosure, my electrical knowledge is close to zero, and despite trying to close the gap by reading up online I'm not much closer to a clear answer on what I imagine is a pretty simple question.
I have some old anglepoise lamps that still need/needed rewiring. I've fitted one and will rewire the rest with three core earthed cable, brass B22 bayonet fittings, and plugs with 3 amp fuses. As far as I'm aware I've done this correctly so far, but I'd like to test that they're safe as all of them are made of metal and are going to see a lot of handling.
I've seen people talking about continuity testing using a multimeter but I'll admit I'm a bit lost on how to go about it and whether it's a function of the cheaper end of multimeters that are within my price range (under £50). I'd be very grateful if someone was able to lend me some advice.
Many thanks.
Professional electricians use calibrated testers rather than multimeters, and they cost way more than £50.00
What we look for is Insulation Resistance... which makes sure each core of the supply flex isnt touching or shorting out with another core.
And continuity. Which tests that each core is continual from point of supply, the plug, to where its going... the lampholder.
Basically it proves that what should be connected, is.... and what shouldnt be, isnt.
If you're not confident in testing, then I would say get someone to test them for you. Will come under Portable Appliance Testing, and most sparks will do it, but a lot of companies want them in some quantity to make it worth their while.
Another option is to use extra low voltage, so the wiring within the lamp is only 12v, say... but then you'de need a transformer/ LED driver and the appropriate lampholder and lamps.
If the lamp is earthed then an earth bond test would also be advisable.
Hi littlespark and DPG, thanks for getting back to me.
I'd considered PAT testing but as it'd only be three or so items I imagine it would come in dear. Just to make sure I'm understanding you right - there's no way to test insulation resistance, continuity and earth bond with a more entry level piece of kit?
You can only do an insulation resistance test and an earth bond test with the appropriate test gear. A multimeter will not be able to carry these out. You could do basic continuity tests, but that's it.
Thank you. Would a continuity test be sufficient to make sure I wouldn't get a shock if something had gone wrong?
An idea that I haven’t used is that charity shops get items PAT tested( they can’t sell anything electrical ) .
perhaps they might test it for you for a small fee.
Some charity shops have a PATesting dept, Oxfam for one but only limited shops. If they are for personal use you could try them.
Cheeky! ?
On the chance I can't sweet talk my local charity shop, would a continuity test be sufficient to make sure I wouldn't get a shock if something had gone wrong?
Reply to Testing lamp is rewired safely in the DIY Electrical Advice area at ElectriciansForums.net
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
Hi, I'll start by saying I'm not an electrician (I'm more of a mechanic), but I like to have a go at wiring on occasion. I'm wanting to make a...
Hi All Sorry for the lengthy first post and use of any non-standard terminology. I'm a bit of a novice when it comes to electronics, hopefully...
19K
