- May 13, 2019
- 6,312
- 1
- 10,286
- 13,648,391
- United Kingdom
- Heavily Qualified Electrician / Teacher / Tutor - etc
It is certainly a good distance away from what i would consider a professional job.
however from what you have shown so far, it is possibly not a big job to put right.
glanding off armoured cables is probabley required but might not be, if the armour is earthed at the other end (i doubt it but it might be)
taped connector blocks just shout "WRONG" at me, BUT it may just be an unused cable being stowed away for later use?
the 3rd photo with the fused isolator, not sure what is wrong with it, maybe i am missing something?
