S
which scheme is he with.....they need to see this....
you would have been better doing it....but i dont think this turnip should be installing...in any capacity...I don't think he is with a scheme and i'm sure he'd struggle to get one!
Terrible standard of work and personally if I was the customer here I would get trading standards in as this is worse than the builders electrics they had on cowboy builders.
To fix this job I would start from scratch
all cables wired in swa enclosed in kopex underground
All joints in suitable ip rated enclosure, with artic or reinforced flex glanded out ip enclosure to light fittings.
Switching
is there any local light switches I.e outside light if so drill through for your feed either fix swa to wall using cleats or enclose in 20/25mm PVC conduit with end box
And make sure you get your money back
If he,d done a job like that for one of my relations it would be me behind bars,he,d be in intensive care!I can just picture a kiddie poking their little fingers into one of those terminal blocks, or even putting one in their mouth. Whoever did that should serve time behind bars.
