H
hsharp
A number of cables are tested for installation resistance. The highest individual value is 200M ohm and the lowest is 20Mohm. The measured value, when all cables are connected in parallel, will be?
A. great than 200M
B. 200M
C. Less than 20M
D. The sum of the individual values.
A. great than 200M
B. 200M
C. Less than 20M
Or
E. prepare to be quizzed on what you think it will be lol
Insulation resistance
What do you know of series and parallel circuits with regard resistance values
wheres he gone?
surely he didn`t expect us to just give it to him (the answer that is)...
Thought this would be an interesting power problem.
Should he not get a few brownie points for the title then Tony
I will give him a clue
3 of them answers are looking a bit suspect
Or
F. Dump the 20meg cable and put it in storage to dry out for future reference then de-rate your mcb as it was probably oversized anyway.
F a). It's Insulation resistance not Installation :)
Good Luck.
Cables in parallel
hsharp,
static zap,
