Discuss Cables in parallel in the UK Electrical Forum area at ElectriciansForums.net
H
hsharp
A number of cables are tested for installation resistance. The highest individual value is 200M ohm and the lowest is 20Mohm. The measured value, when all cables are connected in parallel, will be?
A. great than 200M
B. 200M
C. Less than 20M
D. The sum of the individual values.
A. great than 200M
B. 200M
C. Less than 20M
Or
E. prepare to be quizzed on what you think it will be lol
Is this homework?
Thought this would be an interesting power problem.
Should he not get a few brownie points for the title then Tony
I will give him a clue
3 of them answers are looking a bit suspect
Gets on my nerves when people start a thread and then disappear after 10 minutes. :mad2:
Or
F. Dump the 20meg cable and put it in storage to dry out for future reference then de-rate your mcb as it was probably oversized anyway.
F a). It's Insulation resistance not Installation :)
Good Luck.
Reply to Cables in parallel in the UK Electrical Forum area at ElectriciansForums.net
Commissioning a busduct. My contractor has installed a 2000amp aluminum Busduct in a 17 floor office tower. The specifications state you...
Commissioning a busduct. My contractor has installed a 2000amp aluminum Busduct in a 17 floor office tower. The specifications state you should...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
