H
hsharp
A number of cables are tested for installation resistance. The highest individual value is 200M ohm and the lowest is 20Mohm. The measured value, when all cables are connected in parallel, will be?
A. great than 200M
B. 200M
C. Less than 20M
D. The sum of the individual values.
A. great than 200M
B. 200M
C. Less than 20M
Or
E. prepare to be quizzed on what you think it will be lol
Insulation resistance
What do you know of series and parallel circuits with regard resistance values
wheres he gone?
surely he didn`t expect us to just give it to him (the answer that is)...
Thought this would be an interesting power problem.
Should he not get a few brownie points for the title then Tony
I will give him a clue
3 of them answers are looking a bit suspect
Or
F. Dump the 20meg cable and put it in storage to dry out for future reference then de-rate your mcb as it was probably oversized anyway.
F a). It's Insulation resistance not Installation :)
Good Luck.
Buy a cheap meter and try the practical approach,Maplins resistors !
Work it out what is the total resistance of 200 M ohms and 20 M ohms in parallel. This will answer your question.
When working this out remember that you are measuring resistances in parallel.
The total resistance of resistors in parallel is XXXXer than the XXXXest?
I am trying to be obtuse:ninja:, but I shouldn't have used four I should have used seven or something.:tongue3:
one more go!
Show us your working out mate I'll give u a clue the answer starts with one of the first 4 letters of the alphabet
OHhhh! last chance!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I give up. What's the point in guessing you need to know and understand the formula for resistances in parallel. You need to do a bit of work on this yourself rather than waiting for someone to give it to you on a plate.
Reactions: 2 people
Come on mate I can't c why you don't know the answer to this
come on pal if u look at my first post i told you the answer (c instead of see)
in a parellel circuit the total restistance is always lower then the lowest resistor so in this case the lowest is 20m so it will be lower then that.
if you are a trainee apply for the trainee section and we will all try to help you
parallel resistors
total resistance of resistors in parallel is lower than the lowest individual value
It really is worrying when the questions are multi choice, yet people still try and randomly guess rather than at least attempt to make a educated guess.
Cables in parallel
hsharp,
static zap,
