Search the forum,
Discuss Can I replace an outside wall light with existing wiring in the DIY Electrical Advice area at ElectriciansForums.net
u0362565
Hi all,
I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just need to fix new light to wall and connect the wires to the terminals. I had assumed this would be ok because I'm not adding additional wiring. To me it's similar to replacing a faceplate on a socket in terms of difficulty.
I have read that new installations need to be to current regulations but that depends what you call a new installation. I thought this meant any new wiring. It's a replacement light, just the old one wasnt much use. The wiring won't be to current regs due to its age.
Thanks for the advice
Like for like replacement
if you are competent to do it then get on with it and don’t worry.
Reactions: DPG
Ok thanks, it was just as it's outdoors I wasn't sure. I have replaced indoor light fittings again without modifying wiring.
Reply to Can I replace an outside wall light with existing wiring in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I am trying to replace an old ceiling light with a new one. My current connection has 3 wires and not sure how I should be wiring this...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hello, I have acquired two FOGLIO wall lamps that I want to convert from wall lights into lamps. I'm not familiar with wall lighting so first I...
