Search the forum,
Discuss spd in meter box? in the UK Electrical Forum area at ElectriciansForums.net
Client needs an SPD fitting but no room in c/u or adjacent. Best bet looks like a parallel connection into the tail blocks in the meter cabinet with an adjacent 'standalone unit' ie with overcurrent protection. Anybody done this? Any reason I shouldn't? Is it ok to use board PEN connection block for earth?
Wylex do a tail isolator with type 2 SPD that's rated at 100A so no need to fuse down. This is what I would use just make sure you get your supply and load around the right way round.
Same idea but 1/4 the price...! Have fitted both and not a huge difference in quality tbh , Wylex obvs the benchmark though but I'll be mostly fitting the WCED ..
Reply to spd in meter box? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
Hi all, I've installed a Tesla Gen 3 wall charger supplied by my client. For your information, the place that I installed is in a block of flat...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
We are refurbishing an empty commercial building at the minute and I don't do commercial stuff day in day out so not entirely clued up on...
