Discuss A 702 thing..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've relocated a hot tub from my old house to a new build property and it's failed Part P:
- Using PME of main house.. TT recommended
- Control gear less than 2 metres from zone 0
There's no structural (or any exposed metal) at the external location so guess (1) is wrong? For (2) if all the switchgear (isolator and 3 way MCB enclosure) is IP67 where do I measure the distance? Water (zone 0) to gland of armoured cable (zone 2) or tub case to isolator switch? One way will mean no rewire, the other will! System is fed off separate meter tails via RCCD in garage. Thanks
Reply to A 702 thing..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
Hi all,
First time post to the forums, I hope you all go easy on me!
We are undertaking an electrical install as apart of a solar PV...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
I’m a trainee electrician and would really appreciate the benefit of someone’s skill and experience on the following:
Our house is a TN-C-S (100A...
