Discuss Appliances not working in the UK Electrical Forum area at ElectriciansForums.net
Fosterc92
all of my 20 amp breakers are working fine. But my only double pole breakers are the water heater and a wall heater. Neither of those are working. One leg was getting 120v and the other 80v so I replaced the panel inside the home. Now one leg is 118v and the other is 115v but still the hot water and wall heater aren’t working. Utility company already said the meter was fine. Could it be the incoming main wires to the panel? Just confused as to why the voltage is better but still not working.
Foster welcome to the forum and that sounds odd that all your single pole breakers are working and your double pole breakers are not. By changing the whole panel seemed to help I guess on voltage. Are you reading phase to phase or phase to ground, it sounds like your reading phase to ground so what do you read phase to phase and a picture of the inside your panel would be nice. It sounds like you are loosing a phase
Reply to Appliances not working in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
we just replaced our hot water tank with hot water on demand (natural gas) and still have the old power run for the tank which is 30a 240v. I...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
