Discuss Can I install an EMI filter to an existing solar system without jeopardising my feed in tariff? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I think that filter component is offered to manufacturers of solar inverters as a solution to meeting their EMC requirements.
Your solar inverter will already have a filter arrangement inside, in order that it complies with the standards and gets product approval to be sold. Probably not one of those though.
I can't imagine adding a further filter, eg that one, to your inverter externally will do anything to improve efficiency, and it might actually reduce EMC performance. Optimising an inverters EMC performance, a task that is done by the inverters designers, is a technical job, and one hopes would have been done with considerable thought and many EMC measurements in a very expensive laboratory!
I don't think adding that filter will achieve anything useful.
Reply to Can I install an EMI filter to an existing solar system without jeopardising my feed in tariff? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Can I add solar panels to an existing system without jeopardising my feed in tariff? I have a 3.8kw system but was thinking of adding a few more...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Hi all, as per the above title. If one is to replace the existing solar pv panels for a new system of equal capacity (existing system is 8 x...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
