Discuss Can Wiring to Wall Socket be Laid Horizontally Along Wall at Near Floor Level? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you leave it where it is, it would have to be run in earthed steel conduit, or be run in something like steel wire armoured cable.
Neither of those being easy solutions for you?
Flippin posting thing;
This is what I said: I did mention the capping thing in my #20. My riposte was more subtle, don't you think? :rolleyes:
Either way, round my parts (oo-er) if you leave that bag of sheet like that laid on the floor slab the mice will just chew threw them. Called out to exactly that problem recently where Brian the bodger had rewired the kitchen a year ago and the mice then had an early supper. What happened to personal pride with ones workmanship?
Suggest you sort out your rodent problem then!
I used steel capping a number of times but I always wonder how good it actually is at prevent a nail/screw, let’s be honest they are very thin
It will not prevent a nail or screw from penetrating, this is how it is normally installed is it not? Capping is not classed as mechanical protection, it is simply to protect the cables from the plasterers trowel!
Jay
As I highlighted, that stuff is the equivalent of the plastic stuff. Only useable inside recognised wiring zones, e.g. Fending off the plasterers trowel. does not meet the requirements for cable protection for impact.
Edit: Jay, snap!!
Capping does not provide mechanical protection...
plus I doubt a skirting board will be fitted behind a kitchen unit...
like some of the sparks have advised have it chased in or place it in trunking to give it protection in areas especially were you will be placing the washing machine and dishwasher...
Reply to Can Wiring to Wall Socket be Laid Horizontally Along Wall at Near Floor Level? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
