05gmccarthyg
Hi, above is a picture of some measurements I have taken, and there is a task underneath it that asks me to "Comment on the measured values obtained". I'm not really sure WHAT it is I have to comment on, could someone help me out please?
Thanks a lot. :)
not a very clear pic. mate, but from what i can see, the only comment i can make is that itr shows that the phases are fairly well balanced. (each phase is drawing approx. the same current)
Upvote 0
Thanks for your reply!
I remember my Tutor mentioning the Power Triangle, something to do with using it to work out what the reading SHOULD come out as before actually testing it.
Thanks again.
Upvote 0
if all phase currents were exactly the same the current in the neutral would be 0.
Reactions: 1 person
Upvote 0
Also think about the relationship between the line voltage and phase voltage, ie is the phase voltage exactly a third of the line, or is there some other kind of equation at work here....
Upvote 0
you also need to look at the values you have obtained, and ask if they are right.
Can you get those readings from a 1Kw load?
Apply the power triangle and do a checksum.
Chris
Upvote 0
"Comment on the measured values obtained" <<<< Can you help me please?
Electrician Courses : Electrical Quals
Thread Tags
05gmccarthyg,
kippaxkid,
Electrical Courses
