Discuss complex voltage drop question in the UK Electrical Forum area at ElectriciansForums.net
Bought a set of 4 12v to 24v LED fixtures to test. Circuitry is encased in potting compound in the bottom of the housing.
On the test bench, powered by a variable voltage DC bench power supply and a LUX meter the LED output was a steady 200 LUX at 6" on axis throughout a voltage range of 12.2 to 24V. Output dropped to 190 lux at 12V and substantially less at 11V. Current remained between 3.01 and 3.11 Watts throughout the range. Under AC power the output remained the same 200Lux and 3 to 3.14 watts throughout the range. Oscilloscope showed 60Hz at the LED chip so apparently no rectification in the circuit.
One sacrificial unit was tested for over voltage. Noticeable increase in brightness above 24 volts and I let the smoke out after 30 seconds at 28V.
Looks like I can expect reasonably constant output to the end of 400' of 12/2 fed at 24v AC or DC.
Again, Thanks to all.
Reply to complex voltage drop question in the UK Electrical Forum area at ElectriciansForums.net
I am sending power to some 5v led lights about 50ft from the transformer. I was going to use some CAT6 direct Burial cable that I kept after a...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hi, I'm currently doing my assignment for 2357 and was just making sure I'm calculating the cable length for the lighting circuits right. As...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Hi all, This is my first time posting something on this forum. I'm busy putting together a design for some LED lights that are going to be...
