Discuss Conduit box surround in the Australia area at ElectriciansForums.net
B
brizospark
Replacing a light fitting in a house
The existing fitting is fixed via the conduit box in the wall
Problem is the new light fitting is smaller so wallpaper is not covering area where new fitting is going
I am planning to use the conduit box again as a fixing method
Does anyone know of any sort of clip on surround template or similar for conduit boxes to cover the wallpaper
They make over-sized white plastic/PVC blanking covers for just such a situation, and to hide where plaster/mortar has come away from the sides of the conduit box...
Reply to Conduit box surround in the Australia area at ElectriciansForums.net
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
