Discuss consumer boards (2) in the UK Electrical Forum area at ElectriciansForums.net
M
MARTY16B
hi im currently pricing a job to change a consumer board/s, the question I have is there is a second e7 board, which is no longer in use, but somebody at some point has changed the fused spurs to single sockets. the main concern is ive read before about other sparks putting it all to one board , instead of two(is this ok ??) and they have then had problems with the e7 side tripping out regular , poss because there still using e7 heater's. in my case there arnt any heaters left so is it ok to combine the two boards into one??? any help would be greatfully received asap as im due to change these next week.....:tounge_smile: lso could I change the e7 to be on all the time as they have single sockets instead of fused spurs......thanks fellow sparks hope to hear from you all soooon :D:D
Reply to consumer boards (2) in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
