Discuss Current PV Courses in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
Badged01
OK you solar PV gurus out there, can anyone recommend the 'best' course to attend for being able to install/maintain PV systems? I've done a search of the internet and there seems to be very few places out there doing them now and those that do charge big £'s or aren't currently running any courses! Horror, horror as it sounds to people, the best place I've come across so far for a courseo n my searching is "tradeskills4u" doing the C&G 2399 course. I'm based around the Cardiff/Bristol area.
My interest is not doing PV in the UK and becoming MCS registered but increasing my skill set ready for "retirement" to Spain. I want to be able to install out there and have a reasonable confidence I know what I'm doing! (Although PV is PV, I know there are diff regs/rules etc .... for PV in Spain but I just feel comfortable starting off by knowing the UK way -- we are the best after all :biggrin: )
Views/advice/guidance always gratefully accepted .......
I'd get on the course at the centre for alternative technology if you can, though it's been 14 years since I was down there on courses, and the personnel have probably changed. Ecoskies were pretty good for the heat pump course recently, so would probably be a good bet as well.
These are all only pretty basic courses though.
I did the renewable energy course with CAT many years ago and looked at the CAT course for PV also as the set-up they had seemed got. Never did follow it up though and now it appears like a lot of providers that they dont run it anymore!
Is anyone in Spain still installing PV? I thought the government changes there had completely scuppered the market.
They have with some pretty huge fines if you get caught ---- but if in an area where there isnt access to 'electricity' then you can install
Reply to Current PV Courses in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Is it possible for all or at least most electricians to be trained up in the wiring of solar PV installations, particularly the iBoost or Eddy or...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
