Discuss DC Motor/Generator in the Australia area at ElectriciansForums.net
DC Generator
1.Shaft driven by external source(steam,ac motor etc) at constant speed
2.Field has variable DC excitation
3.Split Commutator gives output voltage(voltage value depends on excitation voltage)
DC Motor
1.No external driving force(steam,ac motor etc) on shaft
2.Constant voltage supply to Split Commutator
3.Field has variable DC excitation resulting in speed control
4.This causes shaft rotation - result motor
Hope this simple explanation helps you
Reply to DC Motor/Generator in the Australia area at ElectriciansForums.net
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Hello, I need to understand whether a DC motor is sturdy or not. The support person told me to measure the armature and field winding resistance...
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
Hello right off the bat I'm a novice with a little better understanding than most(father was a electrician) but I am not an electrician. I'm...
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
