Discuss Dedicated earth on fridge compressor in the UK Electrical Forum area at ElectriciansForums.net
Hello,
I have a quick question...I have been asked if the compressor on a fridge requires dedicated bonding to the body of the fridge? Currently they are not and they pass electrical testing. Does it actually require earthing to the body?
Thank you
Hi - are you saying the compressor is connected to E and the metal fridge frame is connected to this somehow, but you can't see an actual earthing conductor joining the two? Or ...
I guess what i am saying is, does the compressor require a dedicated earth to the fridge body? currently they do not have dedicated earth bonding, and the fridges pass the earth bond tests all the time
EDIT:
and thank you for your responses too
Hello,
Thank you
What testing regime is the fridge passing?
FYI i am using a pat tester, and i usually stick the earth bond cable on a pipe on the compressor as its the easiest pace to get a good connection
Then test using the fridge body to prove the earth bond
the fridge is passing the earth bond test, its passing the load test and the insulation tests.
I have used the fridge body before and they pass, its just it was easier to use a compressor pipe.
ill use the body next time (usually on a screw used for bonding a lid to the fridge)
Good man
would the earth bond test fail if the compressor was not earthed? is the compressor not earthed through the earthing on the power cable?
Most fridges will be connected via a 13Amp plug and the earth continuity linked to all metal parts, at least they should be.
so performing the earth bond test on the compressor pipe confirms its earthed, and doing it to the fridge body confirms the body is earthed. does that mean it doesn't need a dedicated earth bond from the body of the compressor to the fridge body?
Where does the flex from the plug connect to on the fridge?
Where does the flex from the plug connect to on the fridge? Not sure what you mean by a "dedicated earth" all metalwork on the fridge should be earthed via the flexible lead connecting it to the socket.
this is what some of our fridges look like, whereas the ones i'm working on do not have this earthing bar and earth cable.
is this a little over the top?
Reply to Dedicated earth on fridge compressor in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have been having issues with our fridge causing my modem and video card on my pc to drop out. -They are on the same ring circuit, have...
https://www.walmart.com/ip/Minecraft-Green-Creeper-Body-12-Can-Mini-Fridge-8L-2-Door-Ambient-Lighting-25-2-H-9-5-W-9-1-D/2670909566 ok so let me...
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
I have a compressor to be hard wired into a zone 1 container. The container has a 3 phase + E supply but the compressor requires a 3 phase, N & E...
