Discuss dewalt drill in the Electrical Tools and Products area at ElectriciansForums.net
J
james bond
Hi all,
My first posting here and i need some advice
I have a dewalt 18 v drill and it has packed up.
I have stripped it back bare cleaned and checked out the brushes and motor, all seems ok.
Also the battery charger and batterys test out fine with 18 v there.
That led me to think the switch isnt working , but that seems ok as i rigged up a separate 18v supply and the motor on the drill ran ok ??
But when i attach the drills own batterys nothing happens. The batterys are new and the drill is in very good condition and hasnt had much use, trouble is there is no gaurantee.
I have sourced a new switch but i dont want to buy yet until certain that is the fault.
cheers
James
When you rigged up temp did you use the drill battery? If so check the continuity from the drill battery contacts to the switch, if these are OK check the continuity across the switch.
check the contacts where the battery connects to the drill,you know just up the handle?this happened to a mates hilti and they just needed bending out slightly.
Reply to dewalt drill in the Electrical Tools and Products area at ElectriciansForums.net
Just got the latest flyer from Toolstation. Usual stuff, but the front page made me look again. OK, let's remember that Toolstation and Screwfix...
4K
Last year we purchased a home that was built in the late 1990s It has one outbuilding, sort of a barn/shed about 160 feet from the house (and...
I have a surplus brand new unused DeWalt 18v Brushless drill/driver for sale. Got it as part of a promo with a supplier. I have a full range of...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hello friends. I use a Black & Decker 710W Drill. I took a break to get some rest while I was working. The drill was not working when I wanted to...
