Discuss DNO ENA Application Form in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If I am installing a 9kw on a three phase supply and I split the install 3,3,3 then am i correct in saying I need to fill in a G83-1/1 application form? Also does the DNO need informing prior to the installation or can I Install and notify within 28 days?
ok great... to my understanding I thought if for example you were doing two houses on one street, then you need to inform the DNO, hence in this case with 1 building 3 phase and each one has 3kwp per phase, you would need to apply the same rules.
Thanks Bruce,
This building has 2 supplies. We are going to use 1 Inverter on each supply. Would the Single G83 connection still be valid?
No I am wrong by the look of it. I saw the post about 3/3/3, which adds up to 9, without noticing your original post said 17kW, or realising you had two inverters. You are right I think that you are in Stage 2 territory rather than Stage 1.
Regards
Bruce
Thanks Bruce,
so your putting 8.5kw per Mpan? but splitting it between 3 x 1ph inverters on a 3ph supply? Am i reading that right?
Have you thought of Kostal 3ph 4.2/5.5/8.4/10.1 3ph Inverters with 3 mpp on each of the sizes? Just one inverters on each install then or Power-one's 3ph 8kw is out soon or SMA 8kw tripower I think is out now?
If its two supplies on the same property but on separate Mpan's they may want G59
Reply to DNO ENA Application Form in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Hi all I had my PV/Battery setup installed in May and since then all my excess PV is just fed back to the grid for free. When I initially tried...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
