- Reaction score
- 1
ok remember being told that a RCD will provide protection against fire
however I've came across 2 situations where the circuit is protected by a rcd and a fire could of easily started.
first situation where a builder was using a wind up extension lead (not fully unwound) to feed a portable heater, the extension lead plug was badly burnt
the second was at a flat where the night storage heater didn't work, had a look at the c.u and noticed a burnt out chock block on the live, after taking a closer look someone had extended the 2.5mm live with 1mm back to the mcb
now with that in mind am i right saying a rcd will only provide protection against fire if the live/neutral conductor touches earth??
cheers for your help
still learning
still learning
