Discuss Downlights in the UK Electrical Forum area at ElectriciansForums.net
A
Adie
Hello i am in the process of fitting three downlights but there is no earth connection on the lamps,i have run the switched live neutral and earth into a junction box in the loft and than fed x3 1.5mm twin earth to each lamp but not sure if it is alright to terminate the earth wires in choc box at each lamp or do all the earths need to be joined together.
As a bus driver the op probably doesn't know what loop in loop out means... To op please get a local electrician to come and help you
Picture of the lamps.? Why have you run each one individually to a junction in loft and not loop in/out @ each fitting?
Hello,i have run them into a junction box as the electrical connectors on lights is quite compact and thought it might be easier to run individual cable to each light,is the best method to loop in and out and than park the final earth cable in a choc box.Thank you for your reply.
As the fittings are class II, then terminating the cpc in the lamp connector block is OK, at the remote junction box the cpcs should be joined to the supply cpc so that an earth is run to each point (light fitting) in the circuit even though it is not required for the light fittings you show.
What Mr Burns said above ^^^^
Out of interest, what junction box are you using?
Reply to Downlights in the UK Electrical Forum area at ElectriciansForums.net
Hi All Seen this on a few jobs now where they have on the Downlight fittings where the CPC is terminated outside the enclosure of the Downlight...
5K
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
