Discuss Earth on flat plate light switch in the DIY Electrical Advice area at ElectriciansForums.net
T
thelondonstyler
I need to fit a 2 way flat plate light switch. When unscrew the old light switch, I can see the Earth cable connected to the metal box that sits in the wall. The Flat plate switch also has a space for an Earth wire.
So, where should the Earth wire go?
Thanks in advance
Thanks in advance
dunno.
lol.
ideally to both back box and faceplate. the latter being the most important. you either link from back box with a short piece of cable ( sleeved with earth sleeving) or move the connection from back box to faceplate. either way is acceptable, but the faceplate must be earthed.
Reply to Earth on flat plate light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
