Discuss EICR Classification Codes for Downlighters in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
PeterA
Hello,
Can anyone clarify how the following EICR scenarios should be classified?
1. Non IP rated downlights in bathroom inside zone 1
2. Non IP rated downlights in bathroom outside zone 1
3. Non Fire rated downlights in any location
Thanks in advance...
@ OP. just be sure before coding that the downligthers are actually within zones wrt the height. over 2.25m is outside zones.
I thought, C2 for all, but just wanted to check other opinions. Wasn't sure if 'fire rated' were necessary, or just good practice.
Thanks,
What voltage are they?, if they are SELV they maybe OK, but dont quote me, see below.
If you are unsure about fire rating and IP ratings, then check the Electricians guide to the building regs, it will be easier to work out than if you look in BS7671, as you will need to look in a lot of different places to work things out. It is a good while since i last had to fit any downlights, so i am not prepared to comment on whether or not yours should be, as i am not up to date with the latest requirements.
Cheers.................Howard
Reply to EICR Classification Codes for Downlighters in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, I'm refitting my bathroom in my first floor flat (top floor) built around 1989. It has 2 CUs, one for night storage and one for 24h...
4K
