Discuss Electric shower fail :( Gainsborough deluxe 10.5 in the DIY Electrical Advice area at ElectriciansForums.net
th
no hot water thermal cut out have gone .
This is what happened to our shower got one from an online supplier ÂŁ10 or about bit fiddly changed it worked ever since. Don't forget to put the plughole in or cover up in case you drop the small nuts and screws.
Thanks for the tip. Plug in place. Will test today, cheers
Dear all,
I put the continuity probes across the TCO and got a signal. So I guess it was OK. Since the TCO was wired in ( I can't get it out ) I'm not sure if it would have given me a false positive.
I mean to say, the TCO might actually be faulty but still giving me a positive reading. Stuffed if I know.
So I got a new shower engine ÂŁ80 from tradingdepot.co.uk. Cheapest I could find. Even eBay was ÂŁ95.
At least I won't need to drill any new holes. Should be a straight forward job.
When I swap them out, I might investigate the old one just for curiosity.
Cheers for all the advice.
Reply to Electric shower fail :( Gainsborough deluxe 10.5 in the DIY Electrical Advice area at ElectriciansForums.net
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Hello All I was hoping for some advice. We have a microwave and recently after cleaning, as soon as the microwave was plugged in, a loud humming...
