Sharonsusan
- Reaction score
- 0
Hello. I live in MA, in case it has any bearing. My daughters gave me an inflatable hot tub, and my question is re: using an extension cord to plug it in. I had one several yrs ago plugged into one of my outside outlets but they're not working at present (only 1 is attached to the house so I guess theres an issue with the wiring between then, circuit breakers are fine, untripped). Only the outside outlets and basement have circuit breakers, the rest of the house has fuses. Can I use a 12g extension to plug this in? It will likely be set to 80 continually, raised to 100 for a cpl of hrs per night and set up in a shelter logic dome 'shed' and plugged into the closest basement outlet.
