Discuss External lighting control in the UK Electrical Forum area at ElectriciansForums.net
pc1966
The site has 12 * 50W LED floodlights and they are controlled by 2-3 switches (changeover/intermediate) that operate a relay for the actual lights to keep volt drop down. As it has CCTV it would be handy to be able to operate the lights remotely as well. Had it been planned that way in any detail, I'm sure it would be better done differently, but for now I was thinking of using a toggling relay such as this:
To change the lights just like another switch would, my next plan was to use a Raspberry Pi or similar to allow a remote toggle of the state by pulsing the coil for 0.5s or so. My reason for looking at a mechanically latched relay is more so if the computer controlling things is rebooted, etc, it does not default to leaving all lights on in summer, etc. However, there might be a far better/easier way to do this, suggestions folks?
TL;DR Remote toggle of flood lights
Don't know if they are available in the UK, but DIN mounted electronic latching relay's are available on the continent and default open, I find the mechanical latching relay's far too noisy, loud bang as they latch in and out, may not be a problem in a commercial environment.
Any example / links for that?
Here the sound is not an issue, drowned in cooling fans anyway!
This looks even more promising as it has both a toggle input and separate off and on inputs. But no info on power-up state or price:
Was thinking I could change the current switches to momentary to toggle the state, and use the computer control for on/off separately. Maybe even an option to pulse "off" at 9am every day just in case someone forgot and left the lights on.
Reply to External lighting control in the UK Electrical Forum area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Our house has one external feed going outside to power lights. We've recently renovated our garden/drive etc and now there are three different...
R
As an electrician, how often do you get jobs from homeowners to add a 2nd light switch into an existing lighting circuit? Having recently...
Any body come accross remote controled ( internet) lighting ? Was working in area today where i was asked to remove a single lighting point...
monkeyelectric
M
H
I have been called to a customers property and they have a controlled lighting detection system with PIR sensors and external lights. They are...
4K
hursty
H
