Discuss Fluorescent fixture installation in the DIY Electrical Advice area at ElectriciansForums.net
Guildive
Hello -
I am replacing an old fluorescent fixture with a new T8 one, and I wanted to confirm a wiring question.
The old fixture is wired per the photos attached, with a red and blue on one end, and two Romex pairs nutted together and attached to the tombstones on the other end along with the black and white wires from the ballast.
The new fixture I have has blue, red, and yellow wires going to the tombstones and a single connection point for the black/white wires that only leads to the ballast. Wiring diagram for the new ballast is also attached.
I’m assuming I just take the nutted white and nutted black wires from the two Romex cables and connect them to the new ballast, and I’m essentially done.
Just looking for confirmation that this is correct and no fancy re-wiring is needed.
Hello -
You are correct and like you said join the blacks to blacks and so one
Reply to Fluorescent fixture installation in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Info: Located in US I have a 48” T8 fixture that I recently added LED’s by removing the ballast and wiring directly. After doing so when hanging...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
